Altair® Flux®  2022.1 Documentation
2022.1
  1. Home
  2. "How to" Documents
    See a list of documents to understand how to use certain features.
  3. How to use Flux with PBS?
  • User guide
  • What's new?
  • "How to" Documents
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Identification
  • Material Manager
  • Flux e-Machine Toolbox
  • Flux Examples
  • Flux in SimLab Examples
  • Mementos
  • Macros
  • PyFlux Documentation (Beta version)
  • Flux installation guide
  • Parametric distribution with Flux
2022.1
  • User guide
    The user guide gives information about principles and how to use Altair® Flux® 2022.1.
  • What's new?
    See the release notes of the last and previous versions, with the necessary information on new features.
    • How to Configure the Memory in Flux?
    • How to Drive Flux with Compose?
    • How to Experiment with NumPy in Flux?
    • How to Get the Steps of a Scenario?
    • How to import a HyperMesh mesh?
    • How to import a SimLab mesh?
    • How to Launch Flux via Command Line?
    • How to set Flux for batch schedulers?
    • How to Use External Jython Classes in Flux?
    • How to use Flux with PBS?
      • Introduction
      • How to submit a job
      • Input file
    • How to Use Flux with PBS via Display Manager?
    • How to use the Flux-AcuSolve coupling with the Import/Export context?
    • How to use the Flux-OptiStruct coupling with the Import/Export context?
    • How to mesh skin effect?
  • Flux Supervisor
    The Flux supervisor allows to run projects, examples, pythons scripts; to configure user preferences; to access tools...
  • Flux
    Flux is a finite element software for low-frequency electromagnetic and thermal simulations. Both, 2D and 3D solutions are available...
  • Flux Skew
    Flux Skew is a module allowing to facilitate the realization of a quasi 3D or 2 ½ D study starting from a 2D description.
  • Flux PEEC
    Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also provides RLC extraction and generation of SPICE-like equivalent circuits.
    Flux provides a unified Material Identification tool based on the Altair Compose environment allowing to run an identification of the coefficients required to create material in Flux.
  • Material Manager
    Flux has a material manager with its own material base.The user can create his own material base and import them into the Flux models to be studied.
    FeMt is a application in Flux dedicated for Electric Machine which permits to compute and postprocess results like efficiency maps.
  • Flux Examples
    See the lists of examples 2D, 3D, SKEW and PEEC with all available documents and all project and python files.
    See the lists of 2D and 3D SimLab examples using the Flux solver, with all available documents, *.slb databases and all script files.
  • Mementos
    See a list of Memento documents to understand certain Flux features.
  • Macros
    Flux proposes several macros enabling doing actions that are not yet implemented in Flux.
    This documentation deals with the Jython script used in Flux and allows to understand the various structures of entities and functions, and use it in user scripts for example.
    This document provides instructions for Flux installation on supported platforms.
    This document guides you through using parametric distribution with Flux.
2022.1
  1. Home
  • User guide
  • What's new?
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Flux Examples
  • Mementos
  • Macros
Contents
  • Introduction
  • Input file
