Use the Volume Mesh tool to define local volume mesh sizes
on individual solids. You can also choose different volume mesh settings, such as defining
layers on thin regions and quality controls.
These controls will not change the defined surface mesh controls; you must assign
controls to solid body surfaces according to the sizes defined here.
From the Mesh ribbon, click the Volume Mesh tool.
Select solids.
In the dialog, define volume mesh options.
Select Propagate size to surface mesh to pass on the
volume mesh control settings to all the surfaces of the selected solids. If you
already defined surface mesh controls for those solids, the smaller size between
the surface mesh control and the volume mesh control is enforced.
From the guide bar, execute the command in the following
ways:
