HWCFD-T: 2000 Meshing
In this tutorial, you will cover the various meshing tools and options that are available in HyperWorks CFD. The five major mesh controls covered are:
- Surface
- Gap
- Boundary Layer
- Volume Mesh
- Zones
Before you begin, copy the file(s) used in this
tutorial to your working directory.
Set Up Surface Mesh Controls
- Navigate to the Mesh ribbon.
Click the Surface tool.
- Right-click anywhere in the modeling window then pick Select > Advanced Select > By Group > shaft_small_impeller and small_impellers.
- In the microdialog, enter a value of 0.00125 for the average element size and set the geometric feature angle to 30.0.
On the guide bar, click
to execute the command and remain in the tool.
- Right-click on Surface mesh control (50) in the Surface controls legend and select Rename from the context menu. Rename the control to small_impellers or a suitable name of preference.
- Right-click anywhere in the modeling window then pick Select > Advanced Select > By Group > shaft_large_impeller and large_impeller.
- In the microdialog, enter a value of 0.003 for the average element size and set the geometric feature angle to 30.0.
- Right-click on Surface mesh control (27) in the Surface controls legend and select Rename from the context menu. Rename the control to large_impeller or a suitable name of preference.
to execute the command and exit the tool.
Assign a Gap Control for the Whole Geometry
Click the Gap tool.
Figure 3.
- Right-click anywhere in the modeling window and select Show All to display all the solids of the geometry if they're not already visible.
- Press Ctrl + A or left-click and drag over the entire model to select all the surfaces.
In the microdialog:
- Assign a value of 0.025 for Maximum gap between surface.
- Uncheck Restrict minimum gap.
- Select Points Across Gap for the refinement method.
- Assign a value of 4 for the Points across gap.
Set Up Boundary Layers on the Rotating Impellers
Click the Boundary Layer
tool.
Figure 4.
- Right-click anywhere in the modeling window then pick Select > Advanced Select > By Group > small_impellers.
In the microdialog:
- Set the first layer thickness definition to Fraction of Surface Mesh Size.
- Set the total number of layers to 3.
- Choose a Constant growth method
- Right-click on Boundary layer control (46) in the Surface controls legend and select Rename from the context menu. Rename the control to small_impeller or a suitable name of preference.
- Right-click anywhere in the modeling window then pick Select > Advanced Select > By Group > large_impeller.
In the microdialog:
- Set the first layer thickness definition to Fraction of Surface Mesh Size and the first layer thickness factor to 0.01.
- Set the total number of layers to 10.
- Right-click on Boundary layer control (25) in the Surface controls legend and select Rename from the context menu. Rename the control to large_impeller or a suitable name of preference.
- Right-click anywhere in the modeling window then pick Select > Advanced Select > By Group > interface_large_impeller.
In the microdialog:
- Set the first layer thickness definition to Fraction of Surface Mesh Size and the first layer thickness factor to 0.5.
- Set the total number of layers to 1.
- Right-click on Boundary layer control (8) in the Surface controls legend and select Rename from the context menu. Rename the control to large_impeller_interface or a suitable name of preference.
Assign Volume Mesh Controls to the Small Impellers
Click the Volume Mesh
tool.
Figure 5.
- Right-click anywhere in the modeling window then pick Select > Advanced Select > By Solid Bodies > Small impeller 1 and Small impeller 2.
- In the microdialog, set the average size to 0.00125
Create a Refinement Zone for the Mixing Domain
From the Zones tool group, click the
Cylinder tool.
Figure 6.
Snap the cylindrical zone to the center of the shaft as shown in Figure 7. Drag your
mouse and click anywhere on the screen to define a temporary size for the
cylinder. In the radius microdialog, enter a value of
0.54 and press Enter.
Figure 7.
- In the new microdialog, enter a value of 1 for the Height (H) dimension.
- Click on the white arrow pointing in the Y direction to move the zone along the Y-axis.
Enter a value of -0.86 then press Enter to move the zone along the negative Y
direction.
Figure 8.
Enter a value of 0.0025 for the mesh size.
Figure 9.
- Press Esc to exit the tool.
Run a Surface/Volume Batch Mesh
Click the Volume tool.
Figure 10.
- Set a value of 0.005 for the Average element size.
- Check Generate boundary layers on fluid domains only.
Click Mesh to execute the batch mesh process.
Figure 11.
