Other Factors Affecting Fatigue
Surface Condition (Finish and Treatment)
Surface condition is an extremely important factor influencing fatigue strength, as fatigue failures nucleate at the surface. Surface finish and treatment factors are considered to correct the fatigue analysis results.
Surface finish correction factor C f i n i s h is used to characterize the roughness of the surface. It is presented on diagrams that categorize finish by means of qualitative terms such as polished, machined or forged. 1
Figure 1. Surface Finish Correction Factor for Steels
Surface treatment can improve the fatigue strength of components. NITRIDED, SHOT-PEENED, and COLD-ROLLED are considered for surface treatment correction. It is also possible to input a value to specify the surface treatment factor C t r e a t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWG0bGaamOCaiaadwgacaWGHbGaamiDaaqabaaaaa@3BA3@ .
In general cases, the total correction factor is C s u r = C t r e a t   · ​   C f i n i s h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGZbGaamyDaiaadkhaaeqaaOGaeyypa0Jaam4qamaaBaaa leaacaWG0bGaamOCaiaadwgacaWGHbGaamiDaaqabaGccaaMe8UaeS 4JPFMaaGzaVlaaysW7caWGdbWaaSbaaSqaaiaadAgacaWGPbGaamOB aiaadMgacaWGZbGaamiAaaqabaaaaa@4E41@
If treatment type is NITRIDED, then the total correction is C s u r = 2.0   · ​   C f i n i s h ( C t r e a t = 2.0 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGZbGaamyDaiaadkhaaeqaaOGaeyypa0JaaGOmaiaac6ca caaIWaGaaGjbVlabl+y6NjaaygW7caaMe8Uaam4qamaaBaaaleaaca WGMbGaamyAaiaad6gacaWGPbGaam4CaiaadIgaaeqaaOWaaeWaaeaa caWGdbWaaSbaaSqaaiaadshacaWGYbGaamyzaiaadggacaWG0baabe aakiabg2da9iaaikdacaGGUaGaaGimaaGaayjkaiaawMcaaaaa@552A@ .
If treatment type is SHOT-PEENED or COLD-ROLLED, then the total correction is C s u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGZbGaamyDaiaadkhaaeqaaaaa@39D3@ = 1.0. It means you will ignore the effect of surface finish.
The fatigue endurance limit FL will be modified by C s u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGZbGaamyDaiaadkhaaeqaaaaa@39D3@ as: F L ' = F L * C s u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiaadY eacaGGNaGaeyypa0JaamOraiaadYeacaGGQaGaam4qamaaBaaaleaa caWGZbGaamyDaiaadkhaaeqaaaaa@3F6A@ . For two segment S-N curve, the stress at the transition point is also modified by multiplying by C s u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGZbGaamyDaiaadkhaaeqaaaaa@39D3@ .
Surface conditions can be defined in the Assign Material dialog, where you assign them to each part.
Fatigue Strength Reduction Factor
In addition to the factors mentioned above, there are various other factors that could affect the fatigue strength of a structure, that is, notch effect, size effect, loading type. Fatigue strength reduction factor K f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGMbaabeaaaaa@37DD@ is introduced to account for the combined effect of all such corrections. The fatigue endurance limit FL will be modified by K f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGMbaabeaaaaa@37DD@ as: F L ' = F L / K f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiaadY eacaGGNaGaeyypa0JaamOraiaadYeacaGGVaGaam4samaaBaaaleaa caWGMbaabeaaaaa@3D79@
The fatigue strength reduction factor may be defined in the Assign Material dialog and is assigned to parts or sets.
If both C s u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGZbGaamyDaiaadkhaaeqaaaaa@39D3@ and K f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGMbaabeaaaaa@37DD@ are specified, the fatigue endurance limit FL will be modified as: F L ' = F L   ·   C s u r / K f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiaadY eacaGGNaGaeyypa0JaamOraiaadYeacaaMe8UaeS4JPFMaaGjbVlaa doeadaWgaaWcbaGaam4CaiaadwhacaWGYbaabeaakiaac+cacaWGlb WaaSbaaSqaaiaadAgaaeqaaaaa@46EA@
C s u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGZbGaamyDaiaadkhaaeqaaaaa@39D3@ and K f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGMbaabeaaaaa@37DD@ have similar influences on the E-N formula through its elastic part as on the S-N formula. In the elastic part of the E-N formula, a nominal fatigue endurance limit FL is calculated internally from the reversal limit of endurance Nc. FL will be corrected if C s u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGZbGaamyDaiaadkhaaeqaaaaa@39D3@ and K f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGMbaabeaaaaa@37DD@ are presented. The elastic part will be modified as well with the updated nominal fatigue limit.
Temperature Influence
The fatigue strength of a material reduces with an increase in temperature. Temperature influence can be accounted by applying the temperature factor Ctemp to modify the fatigue endurance limit FL.
Ctemp can either by assigned directly, or isothermal temperature across the part/element set can be defined to calculate Ctemp as referred by FKM guidelines for elevated temperatures. The temperature defined must be in degree Celsius.
Ctemp at normal temperature = 1
Ctemp at elevated temperature defined as per FKM guidelines for the following materials is highlighted in the table below.
Ctemp user-defined accepts a value between 0 < Ctemp <= 1
Ctemp set to NONE = 1
Type Temp. Condition Ctemp Factor
None**
this is for materials other than the ones below
- = 1
Fine Grain Structural Steel 60℃ < T < 500℃ =1 - [10-3 x (T/℃)]
Other Steels (other than stainless steel)** 100℃ < T < 500℃ =1 - [1.4*10-3 x (T/℃-100)]
GS (Cast steel and heat treatable cast steel) 100℃ < T < 500℃ =1 - [1.2*10-3 x (T/℃-100)]
GJS (Nodular Cast Iron)
GJM (Malleable Cast Iron)
GJL (Cast iron with lamellar graphite)
100℃ < T < 500℃ =1 - aT,D x (10-3 * T/℃)2
Aluminum materials 50℃ < T < 200℃ =1 - [1.2*10-3 x (T/℃-50)]
Material Group GJS GJM GJL
aT,D 1.6 1.3 1.0
If both Ctemp and Kf are specified, the fatigue endurance limit FL will be modified as: FL' = FL ⋅ Ctemp / Kf
Scatter in Fatigue Material Data
The S-N and E-N curves (and other fatigue properties) of a material is obtained from experiment; through fully reversed rotating bending tests. Due to the large amount of scatter that usually accompanies test results, statistical characterization of the data should also be provided (certainty of survival is used to estimate the worst mean log(N) according to the standard deviation of the curve and a higher reliability level requires a larger certainty of survival).
Figure 2. S-N Curve with Scatter Data
To understand these parameters, let us consider the S-N curve as an example. When S-N testing data is presented in a log-log plot of alternating nominal stress amplitude Sa or range SR versus cycles to failure N, the relationship between S and N can be described by straight line segments. Normally, a one or two segment idealization is used.
Figure 3. One Segment S-N Curve in log-log Scale
Consider the situation where S-N scatter leads to variations in the possible S-N curves for the same material and same sample specimen. Due to natural variations, the results for full reversed rotating bending tests typically lead to variations in data points for both Stress Range (S) and Life (N). Looking at the Log scale, there will be variations in Log(S) and Log(N). Specifically, looking at the variation in life for the same Stress Range applied, you may see a set of data points which look like this.
S 2000.0 2000.0 2000.0 2000.0 2000.0 2000.0
Log (S) 3.3 3.3 3.3 3.3 3.3 3.3
Log (N) 3.9 3.7 3.75 3.79 3.87 3.9
As with many processes, the distribution of Log(N) is assumed to be a Normal Distribution. There is a full population of possible values of log(N) for a particular value of log(S). The mean of this full population set is the true population mean and is unknown. Therefore, statistically estimate the worst true population mean of log(N) based on the user input sample mean SN curve in Materials and Standard Error in the Material DB and My Material tabs of their sample. The SN material data input in the Material DB and My Material tabs is based on the mean of the normal distribution of the scatter in the particular user sample used to generate the data.
Figure 4. Probability Function of the Log(N) Normal Distribution for S-N Scatter. of a particular user-defined sample data
The experimental scatter exists in both Stress Range and Life data. In the Assign Material dialog, the Standard Error of the scatter of log(N) is required as input (SE field for S-N curve). The sample mean is provided by the S-N curve as log ( N i 50 % ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciiBaiaac+ gacaGGNbGaaiikaiaad6eadaqhaaWcbaGaamyAaaqaaiaaiwdacaaI WaGaaiyjaaaakiaacMcaaaa@3E3A@ , whereas, the standard error is input via the SE field in the Assign Material dialog.
If the specified S-N curve is directly utilized, without any perturbation, the sample mean is directly used, leading to a certainty of survival of 50%. This implies that OptiStruct does not perturb the sample mean provided by the user in the Assign Material dialog. Since a value of 50% survival certainty may not be sufficient for all applications, HyperLife can internally perturb the S-N material data to the required certainty of survival defined by you. To accomplish this, the following data is required.
  1. Standard Error of log(N) normal distribution (SE in Assign Material).
  2. Certainty of Survival required for this analysis (Certainty of Survival in the Fatigue Module context).
A normal distribution or gaussian distribution is a probability density function which implies that the total area under the curve is always equal to 1.0.
The user-defined SN curve data is assumed as a normal distribution, which is typically characterized by the following Probability Density Function:(1)
P( x s )= 1 2π σ s 2 e − ( x s − μ s ) 2 2 σ s 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiaacI cacaWG4bWaaSbaaSqaaiaadohaaeqaaOGaaiykaiabg2da9maalaaa baGaaGymaaqaamaakaaabaGaaGOmaiabec8aWjabeo8aZnaaBaaale aacaWGZbaabeaakmaaCaaaleqabaGaaGOmaaaaaeqaaaaakiaadwga daahaaWcbeqaaiabgkHiTmaalaaabaWaaeWaaeaacaWG4bWaaSbaaW qaaiaadohaaeqaaSGaeyOeI0IaeqiVd02aaSbaaWqaaiaadohaaeqa aaWccaGLOaGaayzkaaWaaWbaaWqabeaacaaIYaaaaaWcbaGaaGOmai abeo8aZnaaDaaameaacaWGZbaabaGaaGOmaaaaaaaaaaaa@5180@
Where,
x s MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiEamaaBa aaleaacaWGZbaabeaaaaa@3818@
The data value ( log ( N i ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciiBaiaac+ gacaGGNbGaaiikaiaad6eadaWgaaWcbaGaamyAaaqabaGccaGGPaaa aa@3C17@ ) in the user sample.
μ s MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd02aaS baaSqaaiaadohaaeqaaaaa@38D1@
The sample mean log ( N i s m ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbiqaaWmdciGGSb Gaai4BaiaacEgacaGGOaGaamOtamaaDaaaleaacaWGPbaabaGaam4C aiaad2gaaaGccaGGPaaaaa@3EDD@ .
σ s MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadohaaeqaaaaa@38DE@
The standard deviation of the sample (which is unknown, as the user inputs only Standard Error (SE) in the Assign Material dialog).
The above distribution is the distribution of the user-defined sample, and not the full population space. Since the true population mean is unknown, the estimated range of the true population mean from the sample mean and the sample SE and subsequently use the Certainty of Survival defined by the user to perturb the sample mean.
Standard Error is the standard deviation of the normal distribution created by all the sample means of samples drawn from the full population. From a single sample distribution data, the Standard Error is typically estimated as S E = ( σ s n s ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaiaadw eacqGH9aqpdaqadaqaceaacfWaaSWaaSqaaiabeo8aZnaaBaaameaa caWGZbaabeaaaSqaamaakaaabaGaamOBamaaBaaameaacaWGZbaabe aaaeqaaaaaaOGaayjkaiaawMcaaaaa@3FB0@ , where σ s MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadohaaeqaaaaa@38DE@ is the standard deviation of the sample, and n s MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBamaaBa aaleaacaWGZbaabeaaaaa@380E@ is the number of data values in the sample. The mean of this distribution of all the sample means is actually the same as the true population mean. The certainty of survival provided by the user is applied on this distribution of all the sample means.
The general practice is to convert a normal distribution function into a standard normal distribution curve (which is a normal distribution with mean=0.0 and standard error=1.0). This allows us to directly use the certainty of survival values via Z-tables.
Note: The certainty of survival is equal to the area of the curve under a probability density function between the required sample points of interest. It is possible to calculate the area of the normal distribution curve directly (without transformation to standard normal curve), however, this is computationally intensive compared to a standard lookup Z-table. Therefore, the generally utilized procedure is to first convert the current normal distribution to a standard normal distribution and then use Z-tables to parameterize the input survival certainty.
For the normal distribution of all the sample means, the mean of this distribution is the same as the true population mean μ , the range of which is what you want to estimate.
Statistically, you can estimate the range of true population mean as:(2)
log( N i sm )−z*SE≤μ≤log( N i sm )+z*SE MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciiBaiaac+ gacaGGNbGaaiikaiaad6eadaqhaaWcbaGaamyAaaqaaiaadohacaWG TbaaaOGaaiykaiabgkHiTiaadQhacaGGQaGaam4uaiaadweacqGHKj YOcqaH8oqBcqGHKjYOciGGSbGaai4BaiaacEgacaGGOaGaamOtamaa DaaaleaacaWGPbaabaGaam4Caiaad2gaaaGccaGGPaGaey4kaSIaam OEaiaacQcacaWGtbGaamyraaaa@539A@
That is, (3)
log( N i sm )−z*SE≤log( N i m )≤log( N i sm )+z*SE MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciiBaiaac+ gacaGGNbGaaiikaiaad6eadaqhaaWcbaGaamyAaaqaaiaadohacaWG TbaaaOGaaiykaiabgkHiTiaadQhacaGGQaGaam4uaiaadweacqGHKj YOciGGSbGaai4BaiaacEgacaGGOaGaamOtamaaDaaaleaacaWGPbaa baGaamyBaaaakiaacMcacqGHKjYOciGGSbGaai4BaiaacEgacaGGOa GaamOtamaaDaaaleaacaWGPbaabaGaam4Caiaad2gaaaGccaGGPaGa ey4kaSIaamOEaiaacQcacaWGtbGaamyraaaa@58F7@
Since the value on the left hand side is more conservative, use the following equation to perturb the SN curve:(4)
log( N i m )=log( N i sm )−z*SE MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciiBaiaac+ gacaGGNbGaaiikaiaad6eadaqhaaWcbaGaamyAaaqaaiaad2gaaaGc caGGPaGaeyypa0JaciiBaiaac+gacaGGNbGaaiikaiaad6eadaqhaa WcbaGaamyAaaqaaiaadohacaWGTbaaaOGaaiykaiabgkHiTiaadQha caGGQaGaam4uaiaadweaaaa@4A56@
Where,
log( N i m ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciiBaiaac+ gacaGGNbGaaiikaiaad6eadaqhaaWcbaGaamyAaaqaaiaad2gaaaGc caGGPaaaaa@3D0A@
Perturbed value
log( N i sm ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciiBaiaac+ gacaGGNbGaaiikaiaad6eadaqhaaWcbaGaamyAaaqaaiaadohacaWG TbaaaOGaaiykaaaa@3E02@
User-defined sample mean (SN curve on Materials)
SE MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaiaadw eaaaa@3799@
Standard error (SE on Materials)
The value of z MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOEaaaa@36F6@ is procured from the standard normal distribution Z-tables based on the input value of the certainty of survival. Some typical values of Z for the corresponding certainty of survival values are:
Z-Values (Calculated)
Certainty of Survival (Input)
0.0
50.0
0.5
69.0
1.0
84.0
1.5
93.0
2.0
97.7
3.0
99.9
Based on the above example (S-N), you can see how the S-N curve is modified to the required certainty of survival and standard error input. This technique allows you to handle Fatigue material data scatter using statistical methods and predict data for the required survival probability values.
Adjustment of Multiple SN Curves
The following adjustment is applied to multi-mean stress SN curves, multi-stress ratio SN curves and Haigh diagram.
Uncertainty of fatigue strength of material can be taken into consideration by means of the standard error of log(stress) and certainty of survival.
For example, if the standard error of log(stress) is 0.2, and certainty of survival has to be 99.7%, HyperLife adjusts the multiple SN curves as follows:
  • log(fatigue strength) = log(user defined fatigue strength) – 3 x 0.2
  • Fatigue strength = (user defined fatigue strength ) x 10(-3 x 0.2) .
In the example, user defined fatigue strength is reduced by 3 standard error which corresponds to 99.7% in normalized Gaussian distribution.
Surface Condition and Fatigue Strength Reduction Factor
A factor for surface condition (Cs) and fatigue strength reduction factor (Kf) are applied to fatigue strength in the following manner:
Fatigue strength = (user defined fatigue strength ) * K’
Where,
K’ = 1.0 for N <= 1000
K’ = Cs/Kf for N > Nc1
log(K’) = log(Cs/Kf) x (3-logN) / (3-logNc1) for 1000 < N < Nc1
Nc1 : transition point
References
1 Yung-Li Lee, Jwo. Pan, Richard B. Hathaway and Mark E. Barekey. Fatigue testing and analysis: Theory and practice, Elsevier, 2005
