Find Connectivity
Check the connectivity between two or more components.
Figure 4.
Connectivity Types
Radioss
- Recursive
 - If checked, will isolate and find recursive connectivity.
 - Physical connectivity
 - Checks for node to node connectivity (for 1D, 2D and 3D).
 - RBE2
 - Checks for RBE2 connectivity.
 - Rigids
 - Checks for RBODY connectivity.
 - Interface2
 - Checks for contacts with INTER/TYPE2.
 - Connectors
 - Checks for FE realized connections with connectors.
 - Rigid Links
 - Checks for RLINK connectivity.
 - RBE3
 - Checks for RBE32 connectivity.
 - Joints
 - Checks for CYLJOINT connectivity.
LS-DYNA
 - Constrained Extra Nodes
 - Checks for connections using constrained extra nodes and extra noded joints.
- *CONSTRAINED_EXTRA_NODES
 - Constrained Rigid Bodies
 - Checks for connections using constrained rigid bodies.
- *CONSTRAINED_RIGID_BODIES
 - Constrained Groups
- *CONSTRAINED_TIE-BREAK
 - *CONSTRAINED_TIED_NODES_FAILURE
 - Contact Groups
- *CONTACT_SPOTWELD
 - Connectors
 - Rigid Links
- *CONSTRAINED_NODAL_RIGID_BODY
 - *CONSTRAINED_NODE_SET_ID
 - *CONSTRAINED_GENERALIZED_WELD
 - *CONSTRAINED_SHELL_TO_SOLID
 - Welds
- *CONSTRAINED_SPOTWELD
 - RBE3
- *CONSTRAINED_INTERPOLATION
 - Joints
 - Checks for connections with Joints
 - Slipring and Retractor
 - Checks for connections with sliprings and Retractor
- *ELEMENT_SEATBELT_SLIPRING
 - *ELEMENT_SEATBELT_RETRACTOR
