Create and Edit Laminates
Methods to create and edit laminates in HyperLaminate.
Create Laminates
                Create laminate.
- In the browser, right-click on a sub-type under the Laminate branch and select New from the context menu.
 - In the browser, right-click on a sub-type under the Laminate branch and select New from the File menu.
                        the Laminate branch, then click
 (New) on the
                        toolbar.
A new laminate appears under the selected branch.
A default name and ID are assigned to newly created laminate.
The newly created laminate is automatically selected in the Laminate Browser and the Define/Edit pane takes on the appropriate configuration for the selected material sub-type.
 - If desired, a new name for the laminate may be entered in the Laminate name: field or the component color may be altered by clicking the color swatch and selecting a new color from the pop-up color palette.
 - For OptiStruct and Nastran user profiles, define the Stress and failure theory output: information as desired.
 - For all user profiles, define the Stacking sequence convention: information.
 - For Convention:, select a stacking sequence conventions.
 - If you select Repeat, specify how many times you want to repeat the entire block of entry rows.
                For Ply thickness, select a thickness method.
- Choose Constant to have the Ply lay-up order table include a single thickness column: Thickness T1.
 - Choose Variable to have the Ply lay-up order table include multiple thickness columns.
Note: The option to switch between constant or variable thickness is only available for certain laminate sub-types. -
                For Constant ply thickness, you can check the Common
                        Thickness checkbox and specify a thickness to be used by all the
                    entry rows.
Having checked the Common Thickness checkbox and entered a common thickness value, if you now uncheck the box, the thickness fields retain the common thickness value, but are now editable.
 - Complete the Ply lay-up order table.
                Add/insert rows by completing the Add/Update plies: fields and clicking
                        Add New Ply or Insert New Ply
                    (for Insert New Ply, it is possible to choose to insert the ply above or below
                    the selected rows).
                Note:
The number of rows in the table is not the number of plies. This is governed by the stacking convention and the number of repetitions.
 - Data may be cut, copied from, pasted to, or deleted from selected fields using the toolbar, pull-down Edit menu or Ctrl+X, Ctrl+C, Ctrl+V and Ctrl+D, respectively.
                Table rows may also be cut, copied from, pasted to, or deleted from, using the
                    toolbar, pull-down Edit menu or Ctrl+X, Ctrl+C, Ctrl+V, and Ctrl+D, respectively.
                Note:
Rows are always pasted above selected rows.
When multiple non-sequential rows are copied and then pasted, they will be pasted as sequential rows. For example, if rows 1 and 3 are copied and pasted at row 7, row 1 will be pasted as row 7, row 3 will be pasted as row 8, and what was row 7 will now be row 9.
 - For the OptiStruct and Nastran user profiles it is possible to define thickness and orientation fields in the Ply lay-up order table as designable and to assign design variables to them.
                Click Update Laminate to save the changes for the
                    current HyperLaminate session.
                Note: The HyperMesh database is only updated on exit from HyperLaminate.
Edit Laminates
                In the Laminate Browser, select the laminate to be edited.
                The Define/Edit and Review/Results panes are populated with the selected laminate definition.
 - The laminate definition may be modified in the Define/Edit pane in a manner similar to defining a new laminate.
