hwf::setbackgroundcolor
Changes the background color for all windows in the HyperWorks session.
hwf::setbackgroundcolor color_rgb
HyperWorks Framework
Changes the background color for all windows in the HyperWorks session. The color change affects only the graphics area and it is not stored in the HyperMesh database file or the session file.
Input
color_rgb
The hexadecimal color value.
To set the background color to a dark color, #242424:
hwf::setbackgroundcolor #242424
   # Handle error
Version History
2022.1
