hwISession GetXMLFileHandle
Gets the XML file handle.
hwISession_handle GetXMLFileHandle datafile, filename
HyperWorks Tcl Query
This command gets the XML file handle. Note: To test if the file is actually an XML file, IsValid must be called.
- datafile
- The name that you want to call the XML file handle.
- filename
- The filepath of the file that you want to get the XML handle of. Note: If the filepath has spaces in it, the entire filepath must be within quotes.
hwi GetSessionHandle sess;
sess GetXMLFileHandle XML "c:/Documents and Settings/user/My Documents/hwsettings.xml";
XML IsValid
Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
XML
Query
