::hwp::GetMovie
Gets a movie handle.
::hwp::GetMovie
HyperWorks Tcl Query
This procedure implements minus options.
This procedure returns a movie handle of HyperGraph/HyperView/MotionView.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns the client of the active window.
The GetClient function can check for a particular client type. To do this, use the option "-type". If the check fails, then an error is returned.
The option "-byHandle" is an exclusive option (no other minus options are allowed).
Mandatory Arguments
None.
Optional Arguments
-page "pageID"
The page ID of the requested page.
-window "windowID"
The window ID of the requested window.
-id "the movie id"
Default = 1.
Returns
Returns a movie handle.
set movieHandle [::hwp::GetMovie -page 2 -window 3]
