::hwp::GetModel
Gets a model handle of the animation client.
::hwp::GetModel
HyperWorks Tcl Query
This procedure implements minus options.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns a model handle of the active window.
If no model ID is given, then it returns the active model of the requested client.
Mandatory Arguments
None.
Optional Arguments
-clientHandle "client handle"
The client handle, where the model is requested.
-page "pageID"
The page ID of the requested page.
-window "windowID"
The window ID of the requested window.
-id "modelID"
The model ID of the requested model.
Returns
Returns a model handle of the animation client.
set modelHandle [::hwp::GetModel -id 2]
