::hwp::GetVerticalAxis
Gets an axis handle of a plot client.
HyperWorks Tcl Query
This procedure implements minus options.
This procedure returns a vertical axis handle of HyperGraph.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns a note handle of the active window.
If no axis ID specified, then the primary axis is returned.
Mandatory Arguments
None.
Optional Arguments
-clientHandle "plot client handle"
The handle (object reference to a plot client).
-page "pageID"
The page ID of the requested page.
-window "windowID"
The window ID of the requested window.
-axis "axisID"
The axis ID of the requested note.
Returns
Returns a vertical axis handle of a plot client.
set verticalAxisHandle [::hwp::GetVerticalAxis]
