mdlIModelClient GetObjectPickTypeList
Gets the entity type (body, point, joint, etc.) that can currently be picked by clicking in the graphics area.
mdlIModelClient_Handle GetObjectPickTypeList
MotionView Tcl Query
This command retrieves the currently selected entity pick mode.
Copy the file slider_crank.mdl into the present working directory.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl CreateModel "slider_crank.mdl" mdl
set temp [mcl GetObjectPickTypeList]
puts "The Current Pick Type is $temp"
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
None.
