mdlIObject IsSelected
Determines whether or not an Assembly contains a data/definition file.
mdlIObject_handle IsSelected
MotionView Tcl Query
This command determines if an object is an Assembly or an Assembly Placeholder. If the object (Assembly) has a data file, this command returns true. If there is no data file present, then the Assembly is just an Assembly Placeholder and false is returned.
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetObjectHandle obj_handle
obj_handle AddAssemblyPlaceholder assem_handle assem_0 "\"Assembly Placeholder 0\"" Front_Half  Front_Half;
assem_handle IsSelected
assem_handle ReleaseHandle;
obj_handle AddAssembly assem_handle assem_1 "\"Assembly 1\""  "C:/temp/data_file.mdl"
obj_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandleErrors
Returns true if a data file is already selected for an object, or false if it is not selected (Assembly Placeholder). If there is an error, an error code will be returned.
