pltIDataAttribute SetValue
Sets the value for a data attribute.
pltIDataAttribute_handle SetValue
HyperWorks Tcl Modify
Error
Returns success or an error code.
View new features for HyperWorks Desktop 2022.1.
Gets the label for a data attribute.
Gets the value for a data attribute.
Returns the type of data attribute.
Gets the variable name for a data attribute.
Sets the label for a data attribute.
