pltIPlotManager SetPreloadMaximum
Sets the preload maximum file size for post-processing a large number of pedestrian result files.
pltIPlotManager_handle SetPreloadMaximum size
HyperWorks Tcl Modify
size
The file size in gigabytes. Specifying a size of zero disables this command. Smaller values sacrifice performance for memory and larger values sacrifice memory for performance. Files smaller than the specified size will be loaded into memory entirely.
Change the preload maximum size to 0.5 GB.
hwi GetSessionHandle ses
​ses GetClientManagerHandle plotClientMngr plot
​plotClientMngr SetPreloadMaximum 0.5
Keywords
HyperWorks
Tcl
Macro
Modify
Create
