poICollisionSet GetProximity
Returns the proximity value.
poICollisionSet_handle GetProximity
HyperView Tcl Query
This command returns the proximity value.
Error
Returns the proximity value, otherwise an error code.
View new features for HyperWorks Desktop 2022.1.
Adds selected entities to be used by the collision control.
Returns the event which triggers animation stop.
Returns the binding: part, element, or node.
Returns the proximity state.
Returns the collision set ID.
Returns the collision set label.
Returns a selection list for a given group.
Removes the selected entities.
Clears all selection sets.
Sets the event which triggers animation stop.
Sets the binding: part, element, or node.
Sets the proximity state.
Sets the collision set label.
Sets the proximity value.
HyperView Tcl Query
