poIFLDCtrl RemoveCase
Removes a study case.
poIFLDCtrl_handle RemoveCase
HyperView Tcl Modify
This command removes a study case.
Returns 0 if successful, otherwise an error code.
View new features for HyperWorks Desktop 2022.1.
Adds a study case.
Gets the ID of the active study case.
Gets the color of a particular band of the FLD zone category legend.
Gets the label of a particular band of the FLD zone category legend.
Gets the study case control object for FLD.
Gets a list of study cases.
Gets the curve definition mode.
Gets the current contour type of FLD.
Gets the auto load/unload FLD data state.
Gets the legend control object for FLD.
Gets the ID of the plot window.
Sets the active study case.
Sets the color of a particular band of the FLD zone category legend.
Sets the label of a particular band of the FLD zone category legend.
Sets the curve definition mode.
Sets the FLD contour type.
Sets the auto load/unload FLD data state.
ON THIS PAGE
ON THIS PAGE
