vidIMovie GetNumberOfFrames
Returns the number of frames in the movie.
vidIMovie_handle GetNumberOfFrames
HyperWorks Tcl Query
Returns an integer specifying the number of frames in the loaded movie file.
None.
View new features for HyperWorks Desktop 2022.1.
Returns the filename of the movie.
None.
