The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour
capabilities to isolate key contributing areas.
Generates and post-processes engine order related data from an OptiStruct or Nastran frequency response analysis that contains either RPM-based loading subcases or order-based loading subcases.
The General Signal Processing utility processes the time domain pressure results from CFD simulations and visualizes
the results in both the time and frequency domain.
Predicts powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing
the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
Reads results from an OptiStruct optimization run and processes the results to review the overlay of the NVH responses, baseline versus optimized.
Compare changes in the design variable values, baseline versus optimized.
Define radiation conditions and create emissivity models.
From HyperWorks NVH menu bar, click
NVHPost to display the ribbon. From the ribbon, click on
an icon to open the related tool. Figure 1. NVHPost Ribbon
Integrated Diagnostics
Calculate a response, perform contribution analysis, plot results, and perform diagnostic studies and study response changes.
Modal Participation
Plot modal/panel participation curves from an OptiStruct .h3d file or an MSC Nastran .f06/.pch file.
Grid Participation
The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour capabilities to isolate key contributing areas.
Energy Distribution
Visualize the distribution of energy within a full vehicle NVH model, as a way to understand what components are dominating the vehicle response.
Transfer Path Analysis
Identifies the complex contribution of the excited structure through attachment points to a response in the responding structure.
Design Sensitivity Analysis
Design sensitivity represents a change in response with respect to a change in a design variable, which is typically used for optimization.
Order Analysis
Modal FRF
Calculate a frequency response based on modal results.
Model Correlation
The Model Correlation utility determines the degree of similarity or correlation between two sets of results.
Radiated Sound
The Equivalent Radiated Sound utility post-processes the results of exterior structure-borne radiated sound.
Global Modes
Identifies global modes from an OptiStruct or Nastran modal analysis.
Flow Induced Noise/General Signal Processing
The General Signal Processing utility processes the time domain pressure results from CFD simulations and visualizes the results in both the time and frequency domain.
Mount Optimization
Predicts powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
Optimization, RBDO
Optimizes sensitive parameters for multiple sample analysis results using the RBDO approach.
Multiple Sample Analysis
Post-process results from a Multiple Sample Analysis, including plotting a spread of responses (+/-95% and mean).
Deterministic Optimization
Reads results from an OptiStruct optimization run and processes the results to review the overlay of the NVH responses, baseline versus optimized. Compare changes in the design variable values, baseline versus optimized.
