OS-E: 0915 Cantilever Beam using Equations
Demonstrates how to use the equation utility to define cross-sectional properties in a size (parameter) optimization.
Model Files
The model file used in this example includes:
bar.fem
Model Description
$AREA
DEQATN,111,A(D)=PI(1)*D**2/4
$MOMENT OF INERTIA
DEQATN,122,I(D)=PI(1)*D**4/64
$TORSIONAL CONSTANT
DEQATN,133,J(D)=PI(1)*D**4/32DESVAR,1,Diam1,10,1,20,0.5
DVPREL2,11,PBAR,1,4,,,111
+,DESVAR,1The optimization problem to be solved is the minimization of the tip displacement with a volume constraint of 4000. Convergence was achieved after four iterations.
Results
| Diameter 1 | Diameter 2 | Diameter 3 | Diameter 4 | Diameter 5 | Tip-Displ | |
| Initial | 10.00 | 10.00 | 10.00 | 10.00 | 10.00 | 40.42 |
| Final | 12.48 | 11.49 | 10.28 | 8.70 | 6.29 | 26.51 |
