OS-E: 5000 Conjugate Heat Transfer Analysis (TFSI) of Inline-4 Engine Head with OptiStruct and AcuSolve
The Conjugate Heat Transfer Analysis of a cylinder head to evaluate temperatures in the engine block by taking into account the coupling effect with the fluid domain.
![](../../../images/solvers/tfsi_inline_4_engine_head_fe_model.png)
Figure 1. FE Model
Model Files
The model file used in this example includes:
TFSI_PWT.zip
Model Description
- FE Model
- Element Types
- CHEXA
- MAT1
- Young’s Modulus
- 21500 MPA
- Poisson Ratio
- 0.3
Results
![](../../../images/solvers/tfsi_inline_4_engine_head_temp_contour.png)
Figure 2. Temperature Contour
![](../../../images/solvers/tfsi_inline_4_engine_head_pressure_contour.png)
Figure 3. Pressure Contour on the Fluid Domain
