Bulk Data Entry This parameter is used to control the Automatic Reanalysis process at the end of
Phase 1 in Lattice Optimization.
| Parameter |
Values |
Description |
| LATLB |
<AUTO,
USER or CHECK> |
control the Automatic Reanalysis process at the end of Phase 1 in
- AUTO
- Turns ON the Automatic Reanalysis Process.
- USER (Default)
- Turns OFF the Automatic Reanalysis Process and the
user-defined LB value (or default of 0.1) is used to
generate Lattice Structures for Phase 2.
- CHECK
- This option can be used to run a single reanalysis
iteration and a warning will be output which contains
the percentage difference in compliance between the
original and the reanalyzed structure. The
CHECK option can be used to gain
information about the compliance performance of the
structure using the specified LB. If the compliance
performance is not as expected, then you may consider
rerunning Phase 1 using AUTO to
possibly find a better density Lower Bound (LB).
Refer to Automated Reanalysis in the User Guide
for further information.
