OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
MacNeal-Harder Test This is a twisted cantilever beam solved with solid and shell elements. A model is made with each element's type
to investigate the effect of distorted elements with a high aspect ratio.
MacNeal-Harder Test This is a curved cantilever beam solved with solid and shell elements. A model is made with each element's type to
MacNeal-Harder Test This is a straight cantilever beam solved with solid and shell elements. Three models (rectangular, parallelogram,
trapezoidal) are made with each element's type to investigate the effect of distorted elements with a high
aspect ratio.
MacNeal-Harder Test The Scordelis-Lo Roof is a classical benchmark problem for shell elements. Analytical and experimental investigations
were initially performed by Scordelis and Lo.
Raasch Challenge Raasch challenge is a curved strip hook problem with a tip in-plane shear load, posed in 1990 by Ingo Raasch of BMW
in Germany. The problem poses a significant challenge to shell elements because of the inherent coupling between
three modes of deformation: bending, extension, and twist. OptiStruct is benchmarked against the Raasch challenge to assure its shell elements performance on Linear Static Analysis.
MacNeal-Harder TestThe patch test is a classical benchmark problem for the element, if it produces correct results for the test, the
result for any problem solved with the element will converge toward the correct solution. The intended purpose
of proposed problem set is to ascertain the accuracy of finite element in various applications.
benchmark problem for the element, if it produces correct results for the test, the result
intended purpose of proposed problem set is to ascertain the accuracy of finite element in
Figure 1. Cube subjected to uniform displacement
Benchmark Model
The outer dimension have unit cube of 1mm size. A mesh of cube having node location
as mentioned in the table with first order CHEXA element. The eight corners of the
cube are constrained in all three translational direction and free in all three
rotational directions. Displacement is enforced using SPCD on the eight nodes of
cylinder in X, Y and Z translation directions of the cube.
The material properties are:
Material Properties
Value
Young's Modulus
1 x 106 Pa
Poisson's Ratio
0.25
Figure 2. Patch test for solids
Table 1. Location of Inner Nodes
x
y
z
1
0.249
0.342
0.192
2
0.826
0.288
0.288
3
0.850
0.649
0.263
4
0.273
0.750
0.230
5
0.320
0.186
0.643
6
0.677
0.305
0.683
7
0.788
0.693
0.644
8
0.165
0.745
0.702
The arbitrarily distorted element shapes are an essential part of the test. The
principal virtue of a patch test is that if an element produces correct results for
the test, the results for any problem solved with the element will converge toward
the correct solution as the elements are subdivided. On the other hand, passing the
patch test does not guarantee satisfaction, since the rate of convergence may be too
slow for practical use. The above patch test is an extension of Robinson’s patch
test to three dimensions.
Displacement boundary conditions for the test are:
u
10−3(2x+y+z)/2
v
10−3(x+2y+z)/2
w
10−3(x+y+2z)/2
Results
εx=εy=εz=γxy=γyz=γzx=10−3
σx=σy=σz=2000
τxy=τyz=τzx=400
Figure 3. Elemental strains in all 6 direction plot
Figure 4. Elemental stresses in all 6 direction plot
The results CHEXA elements agree with the reference results.
MacNeal, R.H., and Harder, R.L., A Proposed Standard Set of Problems to Test Finite
Element Accuracy, Finite Elements in Analysis and Design, 1 (1985) 3-20
