OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
OS-V: 1300 Flutter Analysis of an AGARD 445.6 Wing
Flutter analysis of an AGARD 445.6 wing model is performed using the PK
method.
The results are validated against experimental data from a NASA technical
memorandum1.
Benchmark Model
Figure 1. AGARD 445.6 wing model
Dimension details of the model:
Dimension
Value (m)
Span
0.762
Root Chord Length
0.5587
Tip Chord Length
0.3682
The structural domain consists of a stick model with CQUAD4
elements with linear orthotropic material properties.
E1
3.151E+09
E2
4.162E+08
NU12
0.31
G12
4.392E+08
RHO
381.980
Flutter analysis is performed for set of Mach numbers (M) = {0.35, 0.5, 0.7,
0.9} for a velocity range of [120, 330] m/s. In Figure 15 on page 65, the variation
of mass ratios across Mach number suggests difference in flow conditions across the
experiments1. Hence, the density ratios were varied for each Mach
number in separate simulations.
Comparison of Normal Modes
Mode shape and mode frequency comparisons are as follows. The results from OptiStruct are in agreement with the reference results1.
From the .flt file of the first Mach number (M=0.35) simulation,
the flutter point (where damping changes sign) corresponding to the lowest mode is
identified as the 2nd mode with a velocity between 128.89 m/s to 131.12
m/s.
Note: By definition, instability (flutter or divergence) occurs when the
damping values are zero. At this point, if the frequency is zero, then the
instability is due to divergence. Otherwise, the instability is due to
flutter.
Figure 2. Flutter analysis summary from the .flt
file
Plotting the v-g curve, the velocity at this flutter point is 129.417 m/s.
This is the most critical flutter point that needs to be avoided for M = 0.35. Figure 3. Identify flutter points. The flutter point corresponding to
the lowest velocity is also visually identified. Figure 4. Identify the frequency value at the critical flutter point
from the v-f curve.
Plotting the v-f plot for the 1st mode (corresponding to the critical flutter
point), the frequency value for 1st mode at a velocity of 129.417 m/s is
determined as 24.016 Hz. In the same way, the flutter speed and flutter frequency
determination was repeated for M = {0.5, 0.7, 0.9}.
Comparison of Flutter Speed Coefficient
The flutter speed coefficient is calculated from OptiStruct and plotted against M and compared against the
reference plot from Figure 16(a) on page 661.
Where,
Flutter velocity
Streamwise semi chord length at wing root = m
Natural circular frequency of the first uncoupled torsional mode rad/s (This is the 2nd normal
mode for this wing).
Mass ratio.
This value was determined for each Mach number from Figure 15 on page
651.
(1)
Figure 5. Flutter speed coefficient versus M comparison between
experimental reference and OptiStruct flutter
analysis
Comparison of Flutter Frequency Ratio
The flutter frequency ratio is calculated from OptiStruct and plotted against M. This is compared against
the reference plot from Figure 16(b) on page 671.
(2)
Figure 6. Flutter frequency ratio versus M comparison between
analysis
Observations
It is noted that the flutter speed coefficient and flutter frequency ratio
from OptiStruct are in close agreement with the
experimental reference data.
The current support of OptiStruct Aeroelastic
Analysis is limited to Subsonic flow (M < 1.0) and hence the simulations
were not performed beyond M = 0.9. The support for supersonic regime is
planned for a future release and Figure 5 and Figure 6 will be updated with the pertinent data points in this
regime.
In realistic conditions, for M ~ 0.75 and above local pockets of supersonic
flow could occur around the structure. This regime intermediate regime is
denoted as transonic.
In the flutter speed coefficient versus M plot, the experimental reference
data shows a reduction in flutter speed coefficient around M = 1.0 and this
is called the transonic dip.
It can be noted that OptiStruct flutter analysis
is capable of capturing the descent of this dip.
