OS-V: 0450 Free Cylinder: Axi-symmetric Vibration
Test No. FV41 A free cylinder with axi-symmetric vibration. OptiStruct is used to investigate the rigid body mode, close eigenvalues, and the coupling between axial, radial and circumferential behavior.
Figure 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The 1st order and 2nd order triangular axi-symmetric elements (CTAXI) are used to model the cylinder. The cylinder is unsupported.
- Property
- Value
- Young's Modulus
- 200 x 109 N/m2
- Poisson's Ratio
- 0.3
- Density
- 8000 kg/m3
Modal Analysis Results
| Mode | ||||||
| 1 | 2 | 3 | 4 | 5 | 6 | |
| NAFEMS | RBM | 243.53 Hz | 377.41 Hz | 394.11 Hz | 397.72 Hz | 405.28 Hz |
| HOE (8×1) | RBM | 243.34 Hz | 372.14 Hz | 374.18 Hz | 378.22 Hz | 396.00 Hz |
| Normalized | 1 | 1.000780801 | 1.014161337 | 1.053263135 | 1.051557295 | 1.023434343 |
| HOE (16×3) | RBM | 243.46 Hz | 377.15 Hz | 393.2 Hz | 394.6 Hz | 400.97 Hz |
| Normalized | 1 | 1.000287522 | 1.000689381 | 1.002314344 | 1.007906741 | 1.010748934 |
| LOE (8×1) | RBM | 242.45 Hz | 376.02 Hz | 379.86 Hz | 389.83 Hz | 426.92 Hz |
| Normalized | 1 | 1.004454527 | 1.003696612 | 1.037513821 | 1.020239592 | 0.949311346 |
| LOE (16×3) | RBM | 243.28 Hz | 377.69 Hz | 391.42 Hz | 395.54 Hz | 423.00 Hz |
| Normalized | 1 | 1.001027622 | 0.999258651 | 1.006872413 | 1.005511453 | 0.958108747 |
Model Files
- FV41HOEC.fem
- FV41HOEF.fem
- FV41LOEC.fem
- FV41LOEF.fem
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
