OS-V: 0040 Z-Section Cantilever
Test No. LE5 OptiStruct examines the axial (x-x) stress (compression) at mid-surface, point A for linear static analysis.
![](../../../images/solvers/nafems_z_section_cantilever.png)
Figure 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
Quad4 and Quad8 elements are used to create a uniform mesh of 8 elements along the length with one element across width of flange. All the displacements at one end are maintained zero, at the other end two uniformly distributed force of 0.6MN each are applied.
- Material Properties
- Value
- Young's Modulus
- 210 x 103 MPa
- Poisson's Ratio
- 0.3
Linear Static Analysis Results
Quadrilateral Shells | Axial Stress (x-x) at Mid-surface Point A (MPa) | Normalized with the Target Value |
Quad4 | -112.2 | 0.962566845 |
Quad8 | -110.9 | 0.973850316 |
Model Files
- LE5Quad4.fem
- LE5Quad8.fem
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
