OS-E: 6000 Linear Static Analysis
This example demonstrates Rotor Dynamics Linear Static Analysis using two coaxial rotors.
![](../../../images/solvers/rotor_dynamics_os_example_fe_model.png)
Figure 1. FE Model
Model Files
- RD_Lstat.fem
- RD_Lstat_NOGYRO.fem
Model Description
FE Model | 1D Elements |
Material | Material MAT1 | Rotor:
Reference Guide Entries | Keywords | RGYRO, ROTORG, RSPINR, DDVAL, RFORCE |
Results
![](../../../images/solvers/rotor_dynamics_os_example_results1.png)
Figure 2. Maximum Displacement on the Rotor for Subcase 1 with/without RGYRO
![](../../../images/solvers/rotor_dynamics_os_example_results2.png)
Figure 3. Maximum Displacement on the Rotor for the Two Subcases with RGYRO
