OS-V: 0600 Simply Support Beam
OptiStruct is used to investigate the peak Displacement, Stress and Moment in the mid-span node of the beam. The width of the beam is 1.458 in.
![](../../../images/solvers/nafems_response_spectrum_analysis.png)
Figure 1. Cross-section and Dimensions of Beam
Benchmark Model
Rectangular cross-section CBEAM elements are used to model the simply-supported beam which consists of 10 elements. The displacements in x, y, and z direction are fixed at the end A and the displacements in y and z direction and the x rotations are constrained at end B. A Spectrum input in terms of acceleration, velocity and displacement is applied in the vertical direction at both supports. The damping is specified as zero for this problem.
- Property
- Value
- Young's Modulus
- 30 x 106 psi
- Density
- 0.0098 lb-s2/in4
Frequency (Hz) | Displacement (inch) | Velocity (inch/sec) | Acceleration (inch/sec2) |
0 | 0 | 0 | 0 |
5 | 0.783 | 24.599 | 772.80 |
6 | 0.4531 | 17.083 | 644.01 |
6.08 | 0.4316 | 16.538 | 633.66 |
7 | 0.2854 | 12.550 | 552.01 |
8 | 0.2222 | 11.1659 | 561.44 |
Response Spectrum Analysis Results
Model | Spectrum | Displacement (in) |
Stress (lb/in2) |
Moment (lb-in) |
Biggs | 0.56 | 20100.00 | 959500.00 | |
CBEAM | Displacement | 0.55 | 19520.38 | 929716.81 |
Normalized | 1.018 | 1.0296 | 1.0320 | |
CBEAM | Velocity | 0.55 | 19519.60 | 929679.68 |
Normalized | 1.018 | 1.0297 | 1.0320 | |
CBEAM | Acceleration | 0.55 | 19517.91 | 929599.25 |
Normalized | 1.018 | 1.0298 | 1.0321 |
Model Files
- RSAdisp.fem
- RSAvel.fem
- RSAaccl.fem
Reference
J. M. Biggs, Introduction to Structural Dynamics, McGraw-Hill Book Co., Inc., New York, NY, 1964, pg. 262, article 6.4.
