OS-E: 0330 Sine Sweep Fatigue Analysis
Sine Sweep Fatigue Analysis of a simple bracket is done to study the fatigue life of the structure under sinusoidal loading using OptiStruct.
Model Files
The model file used in this example includes:
Analyse_Fatigue_Sinus_v4.fem
Model Description
Frequency Response Stress results from the Frequency Response Analysis are used to calculate the frequency-dependent stress range, which are subsequently used to calculate fatigue damage based on sweep rate. Here the stress-life (SN) approach is used for calculating the fatigue life of the component.
- Bracket
- First order Tetra elements
- Skin Surface Near the Fillet Region
- First order Tria elements
- MAT1 with MATFAT
- Young's Modulus
- 2.1 x 105 N/mm2
- Poisson's Ratio
- 0.3
- Density
- 7.9 x 10-9 ton/mm3
- Shear Modulus
- 0.02 N/mm2
- MATFAT
- Yield Strength
- 180 MPa
- Ultimate Tensile Strength
- 340 MPa
- Fatigue Strength Coefficient
- 936
- First Fatigue Strength Exponent
- -0.161907
- Limit of Endurance
- 1 x 1030
- Fatigue Limit
- 1
