Stress Results Written in HyperMesh .res Format
Static, Eigenvalue, Transient and Multibody Loadcases
ALL, DIRECT and TENSOR Options
von Mises Stress
Maximum Principal Stress
von Mises Stress (Z1)
von Mises Stress (Z2)
von Mises Stress (mid)
P1 (major) Stress (Z1)
P1 (major) Stress (Z2)
P1 (major) Stress (mid)
P1 (major) Stress (max)
P3 (minor) Stress (Z1)
P3 (minor) Stress (Z2)
P3 (minor) Stress (mid)
P3 (minor) Stress (min)
Normal X Stress (Z1)
Normal X Stress (Z2)
Normal X Stress (mid)
Normal Y Stress (Z1)
Normal Y Stress (Z2)
Normal Y Stress (mid)
Shear XY Stress (Z1)
Shear XY Stress (Z2)
Shear XY Stress (mid)
Principal Stress Angle (Z1)
Principal Stress Angle (Z2)
Principal Stress Angle (mid)
Signed von Mises Stress (solid)
P1 (major) Stress (solid)
P2 ( mid ) Stress (solid)
P3 (minor) Stress (solid)
Normal X Stress (solid)
Normal Y Stress (solid)
Normal Z Stress (solid)
Shear XY Stress (solid)
Shear YZ Stress (solid)
Shear XZ Stress (solid)
VON Option
von Mises Stress
PRINC Option
von Mises Stress
Frequency Response Loadcases
Normal X Stress (Z1) (comp)
Normal X Stress (Z2) (comp)
Normal Y Stress (Z1) (comp)
Normal Y Stress (Z2) (comp)
Shear XY Stress (Z1) (comp)
Shear XY Stress (Z2) (comp)
Normal X Stress (solid) (comp)
Normal Y Stress (solid) (comp)
Normal Z Stress (solid) (comp)
Shear XY Stress (solid) (comp)
Shear YZ Stress (solid) (comp)
Shear XZ Stress (solid) (comp)
- "von Mises Stress" and "Maximum Principal Stress" apply to 1D, 2D, and 3D elements simultaneously. Other results apply to 2D or 3D elements exclusively. There are no specific results for 1D elements.
 - For frequency response loadcases, (comp) may be replaced by (real) (imag) (magn) and/or (phas), depending on the complex format request.
 - "Maximum Principal Stress" is the maximum absolute principal stress: max(abs(P1(Z1)),abs(P1(Z2)),abs(P3(Z1)),abs(P3(Z2))) for shells. max(abs(P1),abs(P2),abs(P3)) for solids.
 - "P1 (major) Stress (max)" is the maximum major principal stress: max(P1(Z1),P1(Z2)).
 - "P3 (minor) Stress (min)" is the minimum minor principal stress: min(P3(Z1),P3(Z2)).
 - "Signed von Mises Stress" is the von Mises stress with traction/compression sign: sign(P1+P2+P3) * VonMises.
