OS-E: 0850 V-Bracket using RADOPT
Demonstrates topology optimization of a V-bracket with RADOPT technique, using OptiStruct. RADOPT is Radioss optimization using OptiStruct. The equivalent static load method (ESLM) is used to perform the optimization run here.
![](../../../images/solvers/v_bracket_radopt_fe_model.png)
Figure 1. FE Model
Model Files
The model files used in this example include:
- hook_opt_0001.rad
- hook_opt_0000.rad
- hook_opt.rad
Model Description
- FE Model
- Elements Types
- HEXA
- MAT1
- Young’s Modulus
- 2.1E5 MPA
- Poisson's Ratio
- 0.3
- Density
- 7.9E-9
