RD-V: 0033 Spring (TYPE13)
Spring force as function of elongation for different stiffness formulations.
The subject of this study is to verify the behavior of the spring type beam element with different stiffness formulations, to verify the coupling between shear and bending and finally, different viscous formulations.
Options and Keywords Used
Input Files
The model files used in this problem are available in:
/radioss/verification
Model Description with Different Translational Stiffness Formulations
Units: Mg, s, mm, MPa
- Elastic linear stiffness
- K=2 N/mm
- Nonlinear elastic stiffness
- Force versus displacement function:
- Elongation
- Force
- -20
- -20
- -1
- -10
- 0
- 0
- 1
- 10
- 20
- 20
- Linear stiffness K= 50N/mm used for transition
- Nonlinear plastic stiffness with isotropic hardening
(H=1)
- Same force versus displacement function and same linear stiffness
- Plastic behavior with H=1
- Linear stiffness K= 50N/mm used for transition (between loading and unloading)
- Nonlinear plastic stiffness with uncoupled hardening
(H=2)
- Plastic behavior with H=2
- Nonlinear plastic stiffness with nonlinear unloading
(H=6)
- Nonlinear unloading force versus displacement:
- Elongation
- Force
- -10
- -20
- -5
- -1
- 0
- 0
- 5
- 1
- 10
- 20
- Plastic behavior with H=6
Imposed displacement is defined on one end of the spring element to model positive and negative (+/- 20mm) with constant velocity of 200mm/s for the 3 directions, X, Y and Z. The rotational degrees of freedom at this end of the spring are fixed to see only shear behavior.
The other end of the spring element is clamped, and the 6 degrees of freedom are fixed (/BCS).
Results
Figure 1. force versus elongation
Figure 2. force versus time
| Time | Elastic Linear Stiffness | Nonlinear Elastic | Nonlinear Plastic Stiffness with Isotropic Hardening (H=1) | Nonlinear Plastic Stiffness with Isotropic Hardening (H=2) | Nonlinear Plastic Stiffness with Nonlinear Unloading (H=6) |
| t=0.1s | 40 | 20 | 20 | 20 | 20 |
| t=0.2s | 0 | 0 | -30.10526316 | 0 | -20 |
| t=0.3s | -40 | -20 | -40.63157895 | -20 | -30.52631579 |
| t=0.4s | 0 | 0 | 50.30249307 | 0 | 9.473684211 |
Model Description with Different Rotational Stiffness Formulations
- K= 12.73239545 Nmm/rad
- Moment versus rotation function:
- Elongation
- Force
- -3.141592654
- -20
- -.157079633
- -10
- 0
- 0
- .157079633
- 10
- 3.141592654
- 20
- Linear stiffness K= 318.3098862 Nmm/rad used for transition
(H=1)
- Same moment versus rotation function and same linear stiffness
(H=2)
(H=6)
- Same force versus rotation function and same linear stiffness
- Nonlinear unloading force versus rotation:
- Rotation
- Force
- -1.570796327
- -20
- -.785398163
- -1
- 0
- 0
- .785398163
- 1
- 1.570796327
- 20
Imposed rotation is defined on one end of the spring element to model rotation (+/- rad) with constant rotational velocity of 10. rad /s. The displacement Y and Z at this end of the spring are fixed to avoid shear deformation and see only bending.
The other end of the spring element is clamped.
Results
Figure 3. moments versus rotate
Figure 4. moment versus time
Model Description for Coupling Between Bending and Shear
- K= 20 N/mm
- K= 5000 Nmm/rd
Imposed displacement is defined on one end of the spring element with a value of Y=+/-20mm for the first spring and Z=+/-20mm for the second spring. The rotational degrees of freedom at this end of the spring are free to see shear and bending behavior.
Results
Figure 5. Bending results
The force from the bending moment and the shear force are similar to the reaction force.
The bending moment (measured at the middle of the spring) is also very close to the bending reaction force at the anchorage point.
Model Description for Different Translational Viscous Formulation
- Elongation
- Force
- -5
- -20
- -1
- -10
- 0
- 0
- 1
- 10
- 5
- 20
- Elongation rate dependency
- Linear value
- Stiffness scale factor
- Force versus elongation rate scale factor function:
- Elongation
- Force
- -10
- -0.1
- 0
- 0
- 10
- 0.1
- Damping versus elongation rate function:
- Elongation
- Damping
- -10
- -1
- 0
- 0
- 10
- 1
- Damping versus elongation rate function with higher velocity
The imposed displacement function abscissa (time) is scaled by 0.5 to double the constant loading velocity.
Imposed displacement is defined on one end of the spring element to model tension and compression (displacement +/- 5(mm) with constant velocity of 50mm/s (with abscissa scale factor 1.0) or 100mm/s (with abscissa scale factor 0.5). The rotational degrees of freedom at this end of the spring are fixed to see only shear behavior.
Results
Figure 6. force versus time
| Time | Nonlinear Elastic | Nonlinear Elastic + C | Nonlinear Elastic + Velocity-based Force Function Scale | Nonlinear Elastic + Velocity-based Damping Function (200 mm/s) | Nonlinear Elastic + Velocity-based Damping Function (400 mm/s) |
| t=0.1s (V+) | 20 | 25 | 30 | 25 | 30 |
| t=0.1s (V-) | 20 | 15 | 30 | 15 | 10 |
| t=0.2s (V-) | 0 | -5 | 0 | -5 | -10 |
| t=0.3s (V-) | -20 | -25 | -30 | -25 | -30 |
| t=0.3s (V+) | -20 | -15 | -30 | -15 | -10 |
| t=0.4s (V+) | 0 | 5 | 0 | 5 | 10 |
Model Description for Different Rotational Viscous Formulation
- Rotation
- Moment
- -3.141592654
- -20
- -.157079633
- -10
- 0
- 0
- .157079633
- 10
- 3.141592654
- 20
- Linear value
- Force versus rotation rate scale factor function:
- Elongation
- Force
- -10
- -.636619772
- 0
- 0
- 10
- .636619772
- Damping versus rotation rate function:
- Elongation
- Damping
- -10
- -6.366197724
- 0
- 0
- 10
- 6.366197724
- Damping versus rotation rate function with higher velocity
Imposed rotation is defined on one end of the spring element to model rotation (displacement +/- rd) with constant velocity of 10. rd/s (with abscissa scale factor 1.0) or 20. rd/s (with abscissa scale factor 0.5). The displacement Y and Z at this end of the spring are fixed to avoid shear deformation and see only bending.
Results
Figure 7. moment versus time
| Time | Nonlinear Elastic | Nonlinear Elastic + C | Nonlinear Elastic + Rotational Velocity-based Force Function Scale | Nonlinear Elastic + Rotational Velocity-based Damping Function (200 mm/s) | Nonlinear Elastic + Velocity-based Damping Function (400 mm/s) |
| t=0.1s (V+) | 20 | 40 | 60 | 40 | 60 |
| t=0.1s (V-) | 20 | 0 | 60 | 0 | -20 |
| t=0.2s (V-) | 0 | -20 | 0 | -20 | -40 |
| t=0.3s (V-) | -20 | -40 | 60 | -40 | -60 |
| t=0.3s (V+) | -20 | 0 | 60 | 0 | 20 |
| t=0.4s (V+) | 0 | 20 | 0 | 20 | 40 |
Conclusion
The Radioss computations returns results very close to the theoretical values with the expected behavior for the elastic or plastic behavior.
The coupling between the shear and bending returns the expected results.
The different option to model the translation or rotation rate effect returns the expected results.
