2022.1
Get started with Inspire Extrude Metal.
Setup and perform a quenching analysis.
Discover new features and enhancements.
New to Inspire Extrude? Learn the basics here.
Explore Altair's resources for training and support.
Inspire Extrude Metal offers an analysis tool for virtual testing, validation, correction and optimization of extrusion die designs.
Find answers to Frequently Asked Questions from our users.
Setup and perform an Extrusion analysis.
Setup and perform a Tool Deflection analysis.
A quick overview of the quenching analysis procedure.
Use the Orient tool to set the orientation of the profile.
Use the Profiles tool to create the profile solid by extruding the exit surface of the existing profile part.
Use the Quench System tool to create quench zones that make up the quench system for the profile.
Use the Materials tool to select materials for the analysis.
Select the part to specify the heat transfer boundary condition.
Use the Analysis tool to submit the job for analysis, inspect the job status, perform post-processing and review job history.
Find information about material data blocks in GRF files.
Start using Inspire Extrude with our interactive tutorials.
Get started with Inspire Extrude Polymer.
Get started with Inspire Friction Stir Welding.
Get started with Inspire Resin Transfer Molding.
Create 2D sketches, surfaces, and solids.
