View
View options.
- Zoom In: Enlarge the work screen.
- Zoom Out: Reduce the work screen.
- Zoom Window: Enlarge the work screen by designating area.
- Zoom 1:1: Display at the initial display ratio.
- Mirror: Mirror display of the design data.
Reference List: Open the Reference List
dialog.
- Reference Name View (RV): Select whether to display the reference name in the component area.
- Part Name View (PV): Select whether to display the part name in the component area.
- User Defined Color (UV): Display the selected component area filled with the color.
- B: Select whether to display the X mark.
- F: Select whether to display the first pin mark.
- S: Select whether to display the second pin mark.
- Ref: Display the reference name.
- Part: Display the part name.
- Rot: Display the component’s angle.
- L: Display the component placed layer.
- Display Option: Open the Display Option dialog. Set the displayed items, text size, and user comment.
Label Display: Display the label.
