The Component Arrangement Plan function replaces a paper worksheet with a graphic display report that shows on-board components with their area
and marking at first pin.
When two or more nets are serially connected through passive components such as resistor, electrical analysis must
be made for the entire signal path encompassing the multiple nets connected with these passive components.
Using Properties menu, you can see and edit properties of objects on board or library
link.
Nets
Net properties are basic attributes influencing the electrical analysis.
Composite-Nets
When two or more nets are serially connected through passive components such as resistor, electrical analysis must be made for the entire signal path encompassing the multiple nets connected with these passive components.
Net Classes
You can classify nets according to their electrical characteristics.
