The PollEx SI Explorer is a pre-layout simulation tool. It can be used for experimenting with various topology options to find routing constraints
for critical nets.
For easy building up the practical complex topologies, this feature allows you to study versatile net topologies depending
on signaling types, for example: Single-ended, Differential, and Multi-coupled using built-in topology model libraries.
Net topology analysis is used to construct or view the detailed physical topology of nets schematically and run signal
integrity analysis on the interconnect network model.
Study versatile net topologies depending on signaling types, such as Single-ended, Differential, and Multi-coupled
From the menu bar, click Analysis > Net Topology Analysis.
Click .
the New Model Name dialog appears.
Choose the Net Type.
Depending on the selected Net Type, numbers of topology models which are most
used are displayed configured with driver, receiver(s), (coupled) traces and
termination R&C components. Basically, the simulation procedure is exactly
same as normal simulation procedure.
You can import and use certain parts those are not originally included
in the currently activated design. Such parts can be called from the global
library server or local system. Any sort of parts can be used for composing
complex topologies.
