The PollEx SI Explorer is a pre-layout simulation tool. It can be used for experimenting with various topology options to find routing constraints
for critical nets.
For easy building up the practical complex topologies, this feature allows you to study versatile net topologies depending
on signaling types, for example: Single-ended, Differential, and Multi-coupled using built-in topology model libraries.
