Size Dimension
Definition if the Pin Pad Size Input Type is Size Dimension.
Top Layer: Define the pad shape and size for the top layer.
Connect Pad: Define the connected pad shape and size of the top
layer.
- Pad Shape: Define connected pad shape from Circle, Rectangle, Oblong, or Rounded Rectangle.
- Define size: Circle (diameter), Rectangle/Oblong (width and height), and Rounded Rectangle (width, height, and rounded corner radius) respectively.
layer.
Solder Resist: Define the solder resist pad size using margin from the
pad.
Figure 2. -
Unconnected pad: Define the unconnected pad shape and size.
- If unconnected pad is needed, select the check box.
- Define the pad shape and size.
- Metal mask: Define the metal mask size using margin from the pad.
