Power
Decap
Rule check for whether decap component is connected specific net and checks its count.
  • Item: Input item name.
  • Power Net: Specify Power Net group to which decap component should be connected.
  • GND Net: Specify Ground Net group to which decap component should be connected.
  • Decap Comp: Define target decap component group.
  • Start Comp: Specify component from which the Power/Ground net starts.
  • Pin Type: Specify pin type. (Power/Ground)
  • Min Count: Enter required decap count.
  • Show Total Capacitance: Upon selecting this option, DFE shows the sum of the capacitance value of capacitors connected to each power net.
