List of Running Verification
Click List of running verification.
- Search All
- Search design projects that the verifications are progressed by keyword.
- You can search and get the results with * in the search
term.
Example:
TEST* (Search strings starting with TEST)
*TEST* (Search for strings containing TEST)
*TEST (Search string ending with TEST)
- Advanced search
- You can search by each property’s value.
: Setting of automatic verification.- Verification server: Select the verification server.
- Automatic update: Set whether to update the list automatically.
- Setting count of running daemon: Set the number of verifications that can be executed at the same time.
