You can use Multi-loadcases to run multiple linear structural analyses with common constraints. Linear structural
analysis assumes the model is loaded slowly (static) and stresses do not exceed the yield strength of any part material
(linear).
Linear Structural Analysis
Analysis that assumes the model is loaded slowly (static) and stresses do not exceed the yield strength of any part material (linear).
Non-linear Structural Analysis
Three types of non-linear analysis are currently available: non-linear separating contact, geometric non-linear, and material non-linear.
Multi-loadcases
You can use Multi-loadcases to run multiple linear structural analyses with common constraints. Linear structural analysis assumes the model is loaded slowly (static) and stresses do not exceed the yield strength of any part material (linear).
Sequential
Sequential analysis is any type of structural analysis performed on a structure under prior loading (also termed preloading or prestressing).
