SimSolid
SimSolid
2022.1
  1. Home
  2. Connections
    Connections are used to define the association of different regions of interest between parts in an assembly.
  3. Welds
    Welding is a process that joins materials, usually metals by using heat or pressure.
  • What's New
  • Get Started
  • Tutorials
  • Geometry
  • Assembly
  • Connections
  • Create Analysis
  • Boundary Conditions
  • Post Processing
  • Design Study
  • Verification Problems
Index
SimSolid
2022.1
SimSolid
  • What's New
    View new features for SimSolid 2022.1.
  • Get Started
  • Tutorials
    Discover SimSolid functionality with interactive tutorials.
    Interfaces that support SimSolid output file format.
  • Geometry
    Information about treatment and properties of geometric entities in SimSolid.
  • Assembly
    Summary of available functionality for defining the properties and behavior of parts in the model.
  • Connections
    • Regular Connections
      Regular connections can be used to define contact-based connections between parts in an assembly.
    • Welds
      • Fillet and Seam Welds
        In SimSolid, seam welds are modeled as full 3D solid bodies.
      • Spot and Laser Welds
        Spot weld connects two parts over a circular area on the contacting surfaces. Laser weld connects the contacting surfaces over a strip created along a user-drawn line or a polyline.
    • Adhesives
      Structural adhesives are simulated as thin layers of adhesive material associated with a connection.
    • Virtual Connector
      Virtual connectors are rigid imaginary parts created between selected faces/spots representing geometrical support of the connector.
    • Connection Review
      A table that shows all connections in a specified design study.
    • Review Part Connection Locations
      Diagnose connection problems.
    • Review Part Connections
      Review connections on selected parts.
    • Show Disconnected Groups
      Identify groups of parts that are disconnected from the model.
  • Create Analysis
    Create an analysis for your project.
    Boundary Conditions available for SimSolid.
  • Post Processing
    Run analyses and view a variety of results in SimSolid.
  • Design Study
    Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
    Solved verification models.
SimSolid
SimSolid
2022.1
  1. Home
  2. Connections
  3. Welds
  • What's New
  • Get Started
  • Tutorials
  • Geometry
  • Assembly
  • Connections
  • Create Analysis
  • Post Processing
  • Design Study
Index
Welds
Below are the types of welds supported in SimSolid:
See Also
Spot Welds Tutorial
Seam Welds Tutorial
Seam Welds Video
