2022.1
Measurement of coordinates and dimensions in SimSolid.
View new features for SimSolid 2022.1.
Activate your SimSolid license from within the product.
Short list of hints and tips to get you started with SimSolid.
General workflow overview for SimSolid.
Visual guide for navigating the SimSolid user interface.
Best practices for using SimSolid.
Mouse controls for model view manipulation and component selection in SimSolid
List of keyboard shortcuts available in SimSolid.
You can install and invoke SimSolid from the operating system command line.
A guide to unit management in SimSolid.
Find the distance between two points on the model.
Find the coordinates of points on the model.
Launch a ray through the model and measure lengths of segments where the ray intersects the model surface.
Summary of the settings available for refining SimSolid solutions.
Select default orientation for the Front View of the model.
Generator and browser for user defined views.
Comparison of functions available in SimSolid Basic, SimSolid Standard, and SimSolid Advanced.
Theoretical background of SimSolid and its software implementation workflow, and comparison of other methods used in traditional FEA.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
