2022.1
Solved verification models.
View new features for SimSolid 2022.1.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
The purpose and format of the SimSolid verification problems document.
Learn how to access and download required model files.
Test No. VM01Determine the first fundamental frequency and vibration mode of a wedge constrained at the wide end.
Test No. VM01Find the fundamental frequency for in-plane vibration of a cantilevered plate.
Test No. VM03Find the fundamental frequency of a cantilever cylindrical shell.
Test No. VM04Determine the first fourteen modal frequencies for a free thin square plate.
Test No. VM05Find the fundamental frequency of a thick clamped skewed plate.
Test No. VM06Determine the first twelve modes and frequencies for a simply supported thick square plate.
Test No. VM07Find the first eight modal frequencies for in-plane vibration of a cross with pin joints at the ends.
Test No. VM08Perform normal mode dynamic analysis of a cantilevered beam.
Test No. VM09Perform normal mode dynamic analysis of an unconstrained circular ring.
Test No. VM10Perform a normal mode dynamic analysis of a fixed right triangular plate.
