2022.1
Discover SimSolid functionality with interactive tutorials.
Learn about Analysis in SimSolid.
View new features for SimSolid 2022.1.
Links to SimSolid instructional videos.
Learn how to access and download required model files.
Learn about using other products with SimSolid.
Learn about Assembly in SimSolid.
Learn about Connections in SimSolid.
Learn about Boundary Conditions in SimSolid.
Perform a static structural analysis of a pullup bar assembly.
Run structural sequential (loading and unloading) analysis.
Run structural non-linear analysis in SimSolid.
Review incremental non-linear buckling.
Use modal analysis to calculate the first 3 flexible modes of a bridge assembly.
Apply prestress conditions to modal analysis.
Perform a thermal analysis on a cup model.
Perform a thermal transient analysis.
Learn to use the Multi-loadcases workbench.
Create coupled structural thermal analysis in SimSolid for a piston head.
Create frequency response analysis in SimSolid for a vertical wind turbine assembly.
Create random response analysis in SimSolid.
Run Dynamic Transient Analysis in SimSolid.
Create an SN Time fatigue loadcase.
Import channels and create events automatically using a .csv file.
Create an SN Sequential fatigue loadcase.
Import sequences for SN Sequential fatigue analysis from a .csv file.
Define and run spot weld fatigue analysis.
Define and run seam weld fatigue analysis.
Create global-local analysis.
Learn about Post Processing in SimSolid.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
