Altair Inspire User Guide
2022.1
  1. Home
  2. Structures
    Set up your model and run a structural analysis or optimization.
  3. Model Setup
    Create connections and apply loads, constraints, materials, and manufacturing controls to your model.
  4. Connections
    Create and define connections such as fasteners, joints, connectors, spot welds, and contacts.
  • What's New
  • Get Started
  • Tutorials
  • Parametric Modeling
  • Structures
  • Motion
  • Design Explorer
  • Manufacture
  • Inspire Python API
  • Reference
  • Keyboard Shortcuts and Mouse Controls
Index
2022.1
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire? Learn the basics here.
  • Tutorials
    Start using Inspire with our interactive tutorials.
  • Structures
    • Model Setup
      • Connections
      • Loads and Constraints
        Apply loads and supports, displacements, accelerations, gravity, temperatures, and center of gravity.
      • Materials and Libraries
        Create materials, assign materials to parts, and organize them into libraries.
      • Manufacturing Controls
        Apply manufacturing constraints using shape controls and bead patterns.
    • Structural Analysis
      Set up and run a linear static analysis using the SimSolid or OptiStruct solver. You can also analyze normal modes and buckling modes.
    • Structural Optimization
      Set up and run a topology, topography, gauge, or lattice optimization.
  • Motion
    Set up and run a motion analysis, plot the results, and export the results.
  • Design Explorer
    Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method.
  • Manufacture
    Set up and run a basic porosity or thinning analysis.
    Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
  • Reference
    View the glossary, frequently asked questions, and errors and alerts.
    Learn keyboard shortcuts and mouse controls for common operations.
2022.1
  1. Home
  2. Structures
  3. Model Setup
  4. Connections
  • What's New
  • Get Started
  • Tutorials
  • Structures
  • Motion
  • Design Explorer
  • Manufacture
  • Reference
Index
Connections
  • ../../../Chunk208561451.htm#concept_mnn_wjr_tfb
  • ../../../Chunk497324988.htm#concept_upw_h1g_zz
  • ../../../Chunk945949728.htm#concept_wks_mxq_ccb
  • ../../../Chunk121677185.htm#concept_bkn_msd_dcb
  • ../../../Chunk1954721640.htm#concept_pzr_hkz_b1b
(c) Altair Engineering, Inc. All rights reserved.
