Optimization will find the most effecitve design for each design space in a model in response to the applied loading
conditions on that model. You can run several different types of optimization including topology, topography,gauge,
lattice, and PolyNURBS shape optimization.
When running an optimization, your objective may be to maximize stiffness, maximize frequency, or minimize mass. Different
objectives are available based on the type of optimization selected.
Most optimization constraints are applied using the Run Optimization window. The constraints that are available change
based on the optimization type and objective.
In addition to selecting an optimization type, objective, and constraints, you can also select from a variety of additional
options when running an optimization.
Optimization Types
Several different types of optimization are available in Inspire, including topology, topography, gauge, and lattice optimization.
Optimization Objectives
When running an optimization, your objective may be to maximize stiffness, maximize frequency, or minimize mass. Different objectives are available based on the type of optimization selected.
Optimization Constraints
Most optimization constraints are applied using the Run Optimization window. The constraints that are available change based on the optimization type and objective.
Optimization Options
In addition to selecting an optimization type, objective, and constraints, you can also select from a variety of additional options when running an optimization.
