2022.1
Set up your model and run a structural analysis or optimization.
Set up and run a linear static analysis using the SimSolid or OptiStruct solver. You can also analyze normal modes and buckling modes.
Choose whether to run jobs locally or on a remote job server.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
Create connections and apply loads, constraints, materials, and manufacturing controls to your model.
You can choose whether to use SimSolid or OptiStruct as the solver when running a structural analysis.
Inspire provides several types of linear static analysis results, as well as normal modes and buckling modes analysis.
Set up and run a topology, topography, gauge, or lattice optimization.
Set up and run a motion analysis, plot the results, and export the results.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method.
Set up and run a basic porosity or thinning analysis.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
