2022.1
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method.
Goals comprise objectives and constraints.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
Set up your model and run a structural analysis or optimization.
Set up and run a motion analysis, plot the results, and export the results.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
An output response is a measurement of system performances, such as mass, volume, displacement, or stress.
Use the Evaluate tools to run the exploration and review reports.
Set up and run a basic porosity or thinning analysis.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
