Viewing the Prediction Results
Display the field strength results using the COST 231 - extended Walfisch-Ikegami model.
View the field strength using the COST 231 - extended Walfisch-Ikegami model in the
urban environment.
In the tree, expand
Results: Propagation to view site 1.
In the tree, expand
Site 1 to view the three antennas.
In the tree, expand
Site 1 Antenna 3 to view the Field
Strength and Power entries.
In the tree, click
Power to view the results.
Right-click on the legend and from the right-click context menu, click Thresholds > Auto defined.
Figure 1. Power calculated using the COST 231 - extended Walfisch-Ikegami model.
In the tree, expand
View the power for the indoor database.
- Zoom in on the indoor database.
- Right-click on the legend and from the right-click context menu, click Thresholds > Manual.
- In the Max field, enter a value of -50 dBm.
- In the Min field. enter a value of -90 dBm.
Figure 2. Power calculated using the COST 231 - extended Walfisch-Ikegami model for the indoor database.Note:- Propagation is along straight lines only (always in the vertical plane between transmitter and point of interest).
- The power is lower than with the dominant path model.
- Effects of windows and doors are visible.
